HELP - Need help with Dblookup validation formula
I need assistance with Lotus Notes Domino coding. I am trying to write a command that use the current field (@thisfield) which contains a date to lookup the value in a view prior to saving the form. If the value found in the view has a number greater than four in the key column, then the user can’t save the form and has exceeded the daily limit. Please help. I have a project about to start and need this formula in place to avoid overscheduling.
Here’s my formula:
supgrades:=((@DbLookup(“”:“NoCache”;“”:“”;“Upgrades”;“TotalUpgrades”;“UpgradeDate”;“”)));
PerDay:=@DbColumn(“”:“NoCache”;“”:“”;“_Admin\UnitsPerDay”;1);
@If((SUpgrades *>PerDay);@Failure(“Exceeds Daily limit of 4 per day. Please choose another Ship Date.”);@Success)
Subject: @DbLookup
Sure there are double quotes around TotalUpgrades ? (if this refers to a field, there shouldn’t be).Besides, get rid of the optional “keywords” parameter at the end of your @DbLookup).
Thierry Cayla
http://dominoeffects.serveblog.net
Subject: try substituting this
supgrades:=((@DbLookup(“”:“NoCache”;“”;“Upgrades”;fieldname;“UpgradeDate”;“”)));
