HELP! How we can display FTsearch results documents in a VIEW
Hello,FOR WEB R5 RELEASES…
I want to search the documents according to a key(filled by end user)also in attachments. and also wants to display search documents in a VIEW. please help me by sending some related code or other solution for this problem. please sugest me some code for or related avalable database.
Subject: HELP!! How we can display FTsearch results documents in a VIEW.
this is lotus script…
Dim db As New NotesDatabase( “server”, “dbname” )
Dim view As NotesView
Dim a As Long
Set view = db.GetView( “view anme” )
a = view.FTSearch( “field name”, 0 )
i think this is selly answer…but try once…
For Java…
public int FTSearch(String query)
throws NotesException
public int FTSearch(String query, int field name)
Subject: RE: HELP!! How we can display FTsearch results documents in a VIEW.
hello,actully i want to search(FT SEARCH) in a database n related document collections should be display in a view.
FOR WEB R5 Client
then you can use this syntax…
Call notesDocumentCollection.FTSearch(“”,“”)
You just need to create a URL that uses command ?SearchView&query=x
filling in the full-text query in place of x
The query must be URL-encoded, e.g. …?SearchView&query=FIELD%20Keyword%20=%20%22user%20input%22
You can read about this command in the Designer help. See also @URLEncode.
Hello,I am Very Thankful to you for your kind advice.
Actully i have to implement a function which returns a FT search result in a view(wants to find document in attachments also) or a folder. where end user put a number or string like 10 digit number and click search button and it will display all search result in a view or a folder. I will be very thankfull to you i you please send some RELATED CODE for this problem.
I NEED TO IMPLEMENT THIS FOR A WEB CLIENT ON R5 VERSION.
PLEASE SEND SOME SAMPLE CODE OR RELATED ONE.
THANKS A LOT…
