Help -- How to unsign Agent?
when i was doing a programming and try to open an exist agent, i was notified that the agent is unsigned .so i sign the agent in Administrator. then i can open it , after i edit the Agent ,and i want to restore it back, so what can i do to unsign the Agent?
Subject: Help – How to unsign Agent ?
Perhaps you can write a little LotusScript code using a NotesNoteCollection to get the agent note, and remove its $Signature item.
Subject: RE: Help – How to unsign Agent ?
That would, of course, corrupt the agent. But if never intend to run it again, that would do it.
Signing it again is just as easy.
Resave it with the id you want to sign it with. More details in the Agent FAQ.
