Help for lotus script agent
Hello everybody,In a lotus script agent, I want to create an output file.
The agent is launched by a button on a form
It works well with a notes client but not at all with a web client.
What can i do to make it works with a web client ?
This agent worked very well with Domino V5, even with a web client !
Thank you for your help.
Isabelle.
Here is the code :
Set session = New NotesSession
Set currdoc = session.DocumentContext
Set view = db.GetView(“Export”)
pathName$ = “c:/temp/” & currdoc.NomFichier(0) & “.csv”
’ => I think that it stops here with a web client
fileName$ = Dir$(pathName$, 0)
exists=Dir$(nom$,0)
If fileName$ >“” Then
Kill pathName$
Subject: Help for lotus script agent.
Lotus Script agents launched from the web client execute on the server. They will not be able to create a csv file on your local computer.
If you want to do this from a button, you’ll have to do in JavaScript.
Alex
I think it has something to do with someone from the web, writing to the server itself. It may be seen as a security risk.
My suggestion is possibly having the button on the form create a flag on the document like ‘txtCreateCSV’, and set to ‘Y’, then have an agent, that is signed by an allowable user (yourself), that runs on a schedule, creating it, and doing what you have to do with it.
