Help: exploding 1:5 become 1;2;3;4;5
Hello,
I need to generate range of numbers.
I have two fields:
field_one:= 1;
field_two:= 10;
on other field I would like to explode the two fields above become
1,2,3,4,5,6,7,8,9,10
Any ideas?
Thank’s beforehand,
Glenn
Subject: Help: exploding 1:5 become 1;2;3;4;5
This should do it (no validity checking) ==>
field_one:= 1;
field_two:= 10;
result := field_one;
@For(i:=field_one+1; i<=field_two; i:=i+1;
result := result : i
@Prompt([Ok]; “Test”; @Implode(@Text(result); “~”))
Subject: RE: Help: exploding 1:5 become 1;2;3;4;5
superb!
but on my pc only can generate up to 1626, if I want to go further, an error message appear and says “The formula has exceeded the maximum allowable memory usage”.
Thank’s for your help.
