HELP - Domino hangs with "Insufficient memory - Index pool is full" after update to 6.51
Hi there,
I habe updated my domino 6.5 to 6.51. After this the notes server crashes with the following log events:
20.04.2004 12:29:53 Chronos: Performing hourly full text indexing
20.04.2004 12:30:40 Chronos: Full text indexer terminating
20.04.2004 12:40:59 Admin Process: File name: admin4.nsf: Insufficient memory - index pool is full.
20.04.2004 12:42:25 Error updating view in mail\LOM.nsf: Insufficient memory - index pool is full.
20.04.2004 12:42:59 Admin Process: File name: admin4.nsf: Insufficient memory - index pool is full.
20.04.2004 12:49:26 Error updating view in McAfee\GSD53_Config.nsf: Insufficient memory - index pool is full.
20.04.2004 12:51:12 Error updating view in names.nsf: Insufficient memory - index pool is full.
20.04.2004 12:51:17 Error updating view in admin4.nsf: Insufficient memory - index pool is full.
20.04.2004 12:52:59 Admin Process: Searching Administration Requests database
I’ve already set the DIRMAN_POOLSIZE_MB=100 in notes.ini but I’m not very pleasent with the aswer from IBM:
‘To reduce the frequency with which the problem and error occurs in releases of Domino prior to 6.0.1 CF2, set the NOTES.INI parameter DIRMAN_POOLSIZE_MB=100 to allow the maximum size of the pool to be set to 100MB. Setting this parameter does not fix the problem – it just increases the pool size, and as a result takes longer for the error to occur’
Have anybody a solution for me or similar problems?
Subject: HELP - Domino hangs with “Insufficient memory - Index pool is full” after update to 6.51
SoerenHave you tried running fixup, updall -rx on all databases. If it is a case of one corrupt database causing the issue then it may resolve your issue.
Also check the log to see if after recycling the server the problem occurs with a particular database. If so delete the index using the Administrator.
Since the 6x stream uses the new GTR version there seems to be a lot of postings about this issue.
Regards.
Rm
