Hello all,
Ok, this is my problem/question, I have here different lotus domino server (6.X) and we have a db application that it is also providing a web access. We have created some “doclink” inside one or two document of this db, to some external documents located on the other domino server. These links work perfectly inside lotus itself. But, the generated html does not at all convert these link to url format. There is no html anchor tag (“mydoc”) generated for these links. On the other hand, other local doclink are correctly generated and work good.
Does someone know anything about that ?
For sure, these 2 servers know themselves…Servers know perfectly the dns name / ip of the other (and dont forget that the link work perfectly in lotus side).
So what is wrong ? any fine tuning to do ? or is it just a limitation ?
Help or info greatly wanted ! ![]()
Thanks a lot !
