HELP - Dialogbox and richtext
i use Dialogbox to compose new doc.user input all field and attach file into body field. when user click ok then newdoc will create but body field (richtext type) cannot save with attach file.
please help me.
Subject: Can you post the code you use
Subject: This is my code
Sub Queryopendocument(Source As Notesuiview, Continue As Variant)
continue = False
Dim doc As NotesDocument
Set doc = Source.Documents.GetFirstDocument()
If Not doc Is Nothing Then
 If ws.DialogBox("frVBCD",True, True,False,True,True,,"Update Information",Doc, True,,True) Then
Call doc.Save(True,False)
Call source.View.Refresh
in my frVBCD from, i have 1 richtext field. when i compose document, i can attach file and save document normally.
when i double click in view to edit current document with dialogbox. i can save all change but i can’t save document with attach file
please help me!
