Help configuring DEAS
I just installed DEAS on a Domino 6.5.2 server.
First, it did not update the corporate address book, with the new subforms, I had to search for all the new forms and copied them manually to the pubnames.ntf.
Got that to work and now I see the Mobile tab in the Person documents.
I followed a simple walk through to getting the DEAS SMS Configuration started.
A)- I created a gateway using a forgein document domain
B)- I created a service, gave it a name, and an nsf file to use.
C)- I created an Inbound Connection using the above Service. I am clueless as to which Service Protocol to select (but i chose TAP). Im using a Motorola V220 on the Rogers GPSM network - hopefully this helps.
  • for the Mobile Service Phone Number I entered an IP address of 208.200.67.150, i got this IP by googling for WAP IPs on the Rogers Network.
D)- I created an Outbound Connection using the same config as the Inbound Connection
E)- I created a User Device, 2-way wireless device (alphnumeric)
  • Device PIN Number: I put the cell phones numbers with area code
  • Wireless Service Providor: The name of the Service used above
  • Device e-mail alias: RogersMobile
  • for device password, CAP code, and cost center they are blank because I have no clue what to put here.
  • the rest is default settings
In the Domino Directory, I opened a Person document and in the Mobile tab:
  • Device ID List: USed the PIN number above (which is the phone numbner of the phone)
  • the rest is the default settings.
  • i also created a foreign domain document in the domino directory referencing the name of the service used above.
When I open the server document of the DEAS server and click on the Mobile tab I cannot check the Installed Mobile Components field. I figure that once it’s check I’ll have all those other options for wireless security shown in those screen shots i got from some PDF files.
At this point, what’s left to configure on the DEAS server?
while on DEAS server, whats the address to open the DEAS screen the user should be ‘going too’ via their wireless device? Is there a particular address I can check to see if its up and ‘running’?
On the mobile device, how do I point it to begin retrieving e-mail via the DEAS server?
Any help is appreciated.
Much thanks
ST
Subject: Help configuring DEAS
hi,there- by default, “Installed Mobile Components” checkbox is not editable once you have installed DEAS on current server;
  • set “Java servlet support” to “Domino Servlet Manager” in your server document;
  • set “Language” to English in both server and person document. it seems DEAS (sometimes) set French as default language in Login page;
  • to test your DEAS from browser/mobile device:
www.yourdomainname.com/servlet/deas
if you want to test it on browser from internal network(LAN), then try this:
servername/servlet/deas
  • create customised home page for each mobile user, otherwise DEAS will use “Default” home page document for all users;
hope this helps.
SJ Tian
www.mobilexnet.com
Subject: RE: Help configuring DEAS
Thanks, Shijun.
Stephen,
Why did you create the A trough D steps? Because I didn’t find them at the Domino Everyplace Access Administrator’s Guide?
  • How can I create the “a service, gave it a name, and an nsf file to use”?
  • How can I create the inbound and outbound connections? What are they for?
I’m experiencing the problem below when trying to access the DEAS via mobile phone:
Servlet Status Code: 404
Servlet Status Message: Class com.lotus.MSD.servlet.MSDMain could not be located
Thanks in advance!! Any help will be useful!
Adriana
Adriana:
I responded to your question in another thread:
https://www-10.lotus.com/ldd/nd6forum.nsf/55c38d716d632d9b8525689b005ba1c0/5e1b3b3150db3e4e852571e9006e2116?OpenDocument
