I can use the API for console apps with Visual C++, but not for Windows Forms apps. The compiler and linker directives required for the LN C++ API don’t seem to match the requirements for CLR Windows Forms apps.
Just need to know if I should keep trying, or is the LN C++ API designed only for console applications?
Thanks!
