Group problem
Hi all,
I created a group and i have sent mail to that group . i am also included in that group. but still i didnt get that mail. All other got mail. is that any problem with the group.
veena
Subject: “Works as designed”
Domino/Notes works as designed. As the sender of the email will not receive one even if your are a member of that group. Well, you have the copy of the mail in your “sent” folder. So if you want the group verified, let someelse send a mail to the group, you will then receive it.
Subject: RE: “Works as designed”
thanks peter
