Seeing if anyone can help with this issue.
We have many domains that we manage and there are groups that exist in one domain that need to be e-mailed to from another domain. To accomplish this, we created a separate NAB that replicates across all servers and only contains user and group info, no config or server doc’s. Works great.
The problem that I have is that when users leave the company, someone has to manually remove them from every group that they are member’s of. These groups are NOT maintained on the NAB for each domain, they only reside on this shared NAB so the Delete Person process does not remove them. Unfortunately, as you might imagine, our administrators don’t always remove people in a timely fashion so the groups have to be routinely “cleaned up”.
Is there any way to create either an agent or a program that would scour the groups on the NAB we created and then remove the name(s) I specify?
