I am getting the following when trying to install 8.01 on Linux - Debian.
Am I missing some packages that need to be installed? or ??
Lotus Domino for Unix Install Program
You have to set environment variable DISPLAY to run in graphic mode
Answer Yes to continue in console mode
Answer No to exit application.
Do you want to continue installation in console mode?[Yes]
Continuing in console mode
InstallShield Wizard
Initializing InstallShield Wizard…
Preparing Java™ Virtual Machine…
It won’t continue in console mode or run the graphical installer
