I figured this out - thank you.
With this script, how can I get my History field to be the body of my e-mail message? I am getting the message to send to the Reviewers_1 field, but with no text in the e-mail message. Any help would be greatly appreciated.
Sub Postsave(Source As Notesuidocument)
Dim db As NotesDatabase
Dim uidoc As NotesUIDocument
Dim doc As NotesDocument
Dim doc2 As NotesDocument
Dim item As NotesItem
Set uidoc = workspace.CurrentDocument
Set doc = uidoc.Document
If uidoc.FieldGetText("History") > "" Then
Set doc2 = New NotesDocument(db)
Set item = doc.GetFirstItem("Subject")
Call item.CopyItemToDocument(doc2, "Subject")
Set item = doc.GetFirstItem("Reviewers_1") ' for testing using this field
Call item.CopyItemToDocument(doc2, "SendTo")
Set item = doc.GetFirstItem("History")
Call item.CopyItemToDocument(doc2, "History")
Call doc2.Send(False, doc.Reviewers_1) ' for testing using this field
Else
