Global workbench installation error: location of notes was not found on the system PATH
I am trying to install Global Workbench and I am getting the error ‘The location of Notes was not found on the system PATH. You should add the Notes directory to your PATH or this program may not function’. Has anyone else encountered this error and how was it fixed. Thanks in advance.
Lissa
Subject: Global workbench installation error: location of notes was not found on the system PATH
If you installed Notes in a different path than the default one in Program Files, you’ll have to add this directory to the system path variable.
Are you serious?
