GFI Faxmaker problems any help?
Hello there,
We have set up an pop box for faxmaker to receive it’s messages from.
We made a foreign domain FAX
The problem is as follows :
When we sent an email e.g. 123456789@FAX then the message is sent, but ends up in the sent box of the faxmaker mailfile, but it should endup in the inbox for the Faxmaker to scan this box and receive the message to process.
Is there any body that can help me on this one?
Thnx
Jappe
Subject: GFI Faxmaker problems any help?
You have to modify the design of the view ($POP3) in the faxmaker mailbox. Just delete the selection formula for the view and prevent the view form being updated by the designer task.
