GetFirstItem("Body") returns nothing
Why does itemBody returns nothing if it a failure delivery notification? All emails should have a “body” item? Thanks
session.convertmime = true
Dim itemBody As Variant
doc.GetItemValue (“Body”)
If doc.HasItem(“Body”) Then
 Set itemBody = doc.GetFirstItem("Body")
Subject: GetFirstItem(“Body”) returns nothing
You say it, a body item, you have declared a variant.
try dim itemBody as NotesRichtextitem
Subject: RE: GetFirstItem(“Body”) returns nothing
I try settting to type NotesRichtextitem.
However it gives 'Object variable or With block variable not set ’ when encountered email with embedded pictures , ok with attachment
That why it was declare as variant.
Pls advise
