getDocumentByUrl and extractFile problem
I need to get images from a website, the filenames are structured so i want to loop through the URL’s to the images and download them into a separate database.
Code i done is
Dim webdoc As NotesDocument
Dim xmlAttach As NotesEmbeddedObject
Set webdoc=db.Getdocumentbyurl(“http://www.test.com/test1.gif”, True)
Set xmlAttach = webDoc.GetAttachment(“test1.gif”)
xmlAttach.ExtractFile(“c:\temp\test.gif”)
When debugging in notes i get the obeject XmlAttach with properties filesize, name, type=1454, but when i get to extractfile i get this error “Notes error: Invalid or nonexistent document”.
I also save the webdoc and can verify i have the $File field but the type of that says “Attached”, the code says type OtherObject, so i cant seem to get a handle to it to extract. Is this even possible to do?
Best regards
Thomas
