Get current document using java code
What is the conversion of this code in java? Is this possible?
Dim uidoc As NotesUIDocument
Set uidoc=ws.CurrentDocument
Call uidoc.FieldSetText(“TestField1”)
Subject: Get current document using java code
Found this in the Designer help.
Session session = getSession();
AgentContext agentContext = session.getAgentContext();
// (Your code goes here)
Document doc = agentContext.getDocumentContext();
Thanks!
There is no equivalent since there is no access to the Notes UI in the Java classes.
