FYI Traveler 8.5.1 seems not to work on iPhone OS 4.0 Beta
Hello
Just fyi, seems that authentication with the Server fails after installing the Traveler-Certificate, when using iPhone OS4.0 Beta
regards
Tibor
Subject: Same here, iPhone OS 4.0 = doesnt work with Traveler
Someone at our org finally tried OS 4.0 and got the same result, that was with the latest available fixes for Traveler installed. Anyone seen/found a workaround?
Chris
Subject: Still a problem
and it’s still a problem with the final release. anyone managed to fix it?
Subject: iPhone Success
Maybe this will help…http://www-10.lotus.com/ldd/nd85forum.nsf/ShowMyTopicsAllFlatweb/3787ad6b6606e5cd852577500071ad50?OpenDocument
Subject: Apple’s Fix
Corey Quinn posted a fix from Apple. Check it out here:
http://www-10.lotus.com/ldd/nd85forum.nsf/ShowMyTopicsAllFlatweb/432d74f34a61c27a8525775100097797?OpenDocument
