FYI - Problem with using New NotesDatabase method
FYI -
While troubleshooting a client’s agent LotusScript code running on Domino 6.03 RedHat 8.0 (2.14-18), we discovered the following:
They were using the Set notesDatabase = New NotesDatabase( server$, dbfile$ ) to open an existing database on another server. This worked intermittently. They were getting this error in their log.nsf
Agent ‘agentname’ error: Database server!!sales\targetclass\database.nsf has not been opened yet
This was fixed with two changes:
  1. We changed the LotusScript to use this method
Set notesDatabase = notesSession.GetDatabase( server$, dbfile$)
note: consider adding Is.Open property of the Database class if appropriate
  1. and we found that we needed to change the case of targetclass to targetClass…as this was also causing problems. The folder as it was created on their server was targetClass.
Hope this helps someone.
Subject: FYI - Problem with using New NotesDatabase method
It is hard to accept this because we only have a snippet of the code.
Here is a simple agent I wrote to test the opening of a database on a different server:
Dim Db As NotesDatabase, otherdb As NotesDatabase, doc As NotesDocument, view As NotesView
Dim ServerNameString As String
ServerNameString = "ServerName/OrgName"
Set otherdb = New NotesDatabase(ServerNameString, "log.nsf")
If Not(otherdb.Title = "") Then
	Msgbox "got a database on " & ServerNameString
	Set view = otherdb.GetView("Miscellaneous Events")
	Msgbox "got view"
	Msgbox "got a doc"
	If Not(doc Is Nothing) Then
		Msgbox "got doc " & doc.Created & " was when it was created."
As you can see I am using the method you are reporting as an error.
HTH – Cheers
Subject: RE: FYI - Problem with using New NotesDatabase method
Hi Joe,
How do I use this agent? Where do I save it at? I am pretty new to Lotus Notes.
Thanks for your help.
DN
Thanks - don’t panic, these are known “gotchas”: as you’ve discovered, you should always test a NotesDatabase object to check that it’s actually open; if you’ve not opened it before, and don’t do an explicit test, you get the error you’re experiencing.
The other one’s a doozie: Linux / Unix based OSes are case sensitive!
Hope all goes well with your app.
