Fundamental problem: Fields-level mismatches in the replicas
Dear colleagues,
Did you ever saw fields-level mismatches in the replicas? When “Modified (Initially)” is equal, but content is different (ugh…)
No? Never? May be it’s time to check? :slight_smile:
My company detects this issue more than year ago, in many databases and servers, even in cluster members. We try to solve it, but still without much success (even with a help from IBM).
So… If you want to check your databases you can use “ReplicasMatcher” tool. It is destined to match documents from different replicas on the field’s level. It is also possible to merge unmatched documents.
Please download it from here - http://redir.ec/replicasmatcher (you can find all manuals in the Using and About documents).
If you have also experienced such troubles, or will detect it with ReplicasMatcher - please let me know.
It is good to know that you are not alone struggling against this disaster :slight_smile:
Best regards,
Pavel Severov
severov@gmail.com
Subject: Please don’t crosspost.
Keep your questions in one forum, the one related to your version of Notes/Domino.
http://www-10.lotus.com/ldd/nd85forum.nsf/DateAllThreadedWeb/3b86c0e3185ade2f85257b3b005d11c9?OpenDocument
Subject: Re: Please don’t crosspost
Thanks for the reply.
Following Domino versions has been affected with this issue:
  • R7
  • R8
  • R85
That was the reason for posting into “Notes/Domino 8” and “Notes/Domino 8.5”. Is it incorrect?
And should I also post this into “Notes/Domino 6 & 7”? :slight_smile:
Subject: No.
Post in one forum. If it affect multiple versions, mention that in the post. But put it in the forum for the current version, or possibly the most common version.
But your post sounds very much like an ad, it should not even be here.
Subject: Stop posting adverts disguised as problems
Subject: Too much expression, right? :slight_smile: Sorry.
Unfortunately this is not an advert but the disaster report.This problem put Notes/Domino at risk to be replaced with more reliable platform in my company.
Subject: Maybe make it an openntf project?
