Full-Text Search: works and does not work across copies and replicas
Full Text Query: (Field Year = 2011)Field Name: Year
Field Type: Number
Copies and Replicas of databases:
Domino Server | Query Returns Documents
6.5.5 Yes
7.0.1 No
8.0.2 Yes
8.5.2 No
My production server for this app is running 7.0.1. however I think I may have a field type problem.
On Servers that work I can use the Query Builder Field option. When I pick the field Year from the list, the dropdown lets me pick “is equal to”.
When I use the Query Builder on the servers that don’t work, the dropdown lets me pick “is on”.
Could this be a data type problem for the field? Any suggestions to get this full-text query to work will be greatly appreciated.
  • Gary
Subject: Full-text Solution
I tried the following with no success:1. delete the index.
  1. run agent that deletes field and then adds it again with the value as a number.
  2. Create full-text index.
This worked:
  1. delete the index
  2. run agent that copies the value from Year field to RegYear field.
  3. Create full-text index.
  4. Change code to use RegYear instead of Year field.
