If the person have used return receipt while sending mail, he also receives a received mail with my name after I use full access administration and open the mail. How can I prevent it?
Subject: full access administration problem with return receipt
We’ve setup a Rule in the server configuration document to delete any messages that contain Form of type Return Receipt and Sender = Admin Names
Works well for us…
Subject: RE: full access administration problem with return receipt
Another, much easier, solution is to select (not open) the mail message and click on ‘Forward’. This puts the original message in a new memo without making it ‘read’ or triggering a receipt.
Or you could go to the Document Properties (without opening the message) and take a look at the Body field on the second tab!!
Thanks for your help.
