Hi !
I am working on a migration from Domino 6.5 to Domino 8.5.1.
With the Domino 6.5 server, a search with FTSearch brings 2 documents of 1682 as the user can show only these 2 documents. This is correct.
With the Domino 8.5.1 server, the same search in the same database for the same user (same rights) brings 1682 documents. But, 1680 documents are like ghosts. That means : no data, no form (msgbox doc.form(0) => “”).
I have rebuilt the database index in Domino 8.5.1 server. Same problem.
Any idea to correct this huge problem (all applications use FTSearch…) will be appreciated…
Thanks !!
