Frameset Refresh Problem
Hi All,I need help, I have used a framset in our web based application, when i perform logout action after that when I want to open again that frameset so there are multiple login window opened for login(according to my framset structure) , i think this is refresh problem bcz when i click on refreh button in the IE then only one login window promp to login.
i will appreciated to quick response.
thanx & regards
Zubair A khan
Subject: Frameset Refresh Problem
This is because the contents of the frameset are trying to connect, but the frameset itself doesn’t refresh (unless you do it manually.) What I did is put a javascript on the login page that runs whenever you load it to breakout of any frameset.
Put this javascript in your $$LoginUserForm…
…and then call it in your onLoad event on that form…
noFrame();
