Frame set should look with the same width in both notes client and web. As of now , frame width differs in notes client and webIs there any way to control the width of the frame , so that it looks similar in both client and web
Subject: Frame width in web
If you resize the frame in Designer (say, drag it so the left frame is less wide), it shows up resized on the Web. Can you provide more details about what you’re trying to do?
Subject: RE: Frame width in web
Hi,Thanks for ur response. I have db opening with frameset. This db front page i.e. Frameset should look similar both in notesclient and in web. If i try resizing frameset in client , it affects in web too. But has different width in client and web.
Is there any coding involved to resize the width of the frame in web or is it just trial and error to make this frameset similar in both cases?
