Frame issue
I have a 2 pane frame. On the left side, its pointing to a page (with an outline), and one the right its defaulting to a view. Whenever I select one of the views on the left-hand side, the frame goes away. How do I make the left-hand pane always stay in palce no matter what view is chosen? I’ve tried several things, but can’t get the frame to stay put. TIA…I know this is something probably simple.
Subject: Frame issue
Did you try setting the default target for links in the frame to the name of your right frame?
Subject: RE: Frame issue
Yes, I set the default target frame on the left to the name of the frame on the right, and it still makes the left hand frame disappear when I click a view link.
how are your links coded in the left frame?
They are just referencing views in the Outline. I got it working. I was referencing a Target in the Outline entry, and that needed to be blank.
Thanks to everyone for your help!
Set the correct frame in each outline entry.
