Frame and HelpUsingDatabase
Hi all,
Funny situation:
I have a navigator with a button which has the command HelpUsingDatabase. When i test the navigator, the action works fine. But when I embed the navigator in a frame and clcik th ebutton it opens the Lotus Notes Help Database. It’s the same for HelpAboutDatabase.
Has anyone come across this issue? And any suggestions on correcting? I know I could just use navigators but a frame works faster for what I need to design.
TIA
Subject: Frame and HelpUsingDatabase
Hi Jeff - unfortunately, I can confirm that whatever is causing this, it hasn’t been fixed in 7.0.2.
It does work if your button is on a page though - any reason why you particularly need to use a Navigator?
Emily.
Subject: RE: Frame and HelpUsingDatabase
Emily,
Cheers for the reply, shame to hear it though. We’re using a Navigator because of the way it allows use to present things to the users. I guess I’ll take a better look at pages and see what I get.
Have a great weekend!
Jeff
Don’t forget to look at Layers for more precise control over where things are displayed on the screen in ND6. This may help you get your page looking more like a Navigator.
Emily.
