hi everyone,I’m wondering if it is possible to compose a mail with a function formula and a part of it will be a section? I know how to compose the mail but not how to create the section.
The CreateSection command only covers selected text. Maybe there is a way to autoselect a specific range of the text?
Thank you for your help,
Elliott
Subject: maybe this?
take a look at @Command([ComposeWithReference]). Not sure if you can achieve what you want but it has some switches for sections.
Subject: multiple sections
Hi Paul, Thank you very much for your suggestion unfortunately I believe those can only be used to reference an existing document and I think it would give you at most one section. I need to compile a report where each entry consists of a date, a brief summary and then a section (collapsed by default) of the detailed summary.
Please let me know if there is anything anyone else can think of.
Thanks for all your help,
Elliott
Subject: OK, try this
take a look at BeginSection method of NotesRichTextItem. There is an example in there which shows you how to do what you want, not exactly. I did some testing and was able to achieve what you want, creating multiple collapsed sections in a RichText Body field of a document.
Dim ns As New NotesSession
Dim db As NotesDatabase
Set db = ns.CurrentDatabase
Dim doc As NotesDocument
Set doc = ns.DocumentContext
Dim rti As NotesRichTextItem
Set rti = doc.GetfirstItem("Body")
Dim rtstyle As NotesRichTextStyle
Set rtstyle = ns.CreateRichTextStyle
rtstyle.Bold = True
Dim colorObject As NotesColorObject
Set colorObject = ns.CreateColorObject
colorObject.NotesColor = COLOR_RED
Call rti.BeginSection("section 1", rtstyle, colorObject, False)
Call rti.AppendText("help me")
Call rti.EndSection
Call rti.AddNewline(2)
Call rti.BeginSection("section 2", rtstyle, colorObject, False)
Call rti.EndSection
Call rti.BeginSection("section 3", rtstyle, colorObject, False)
Call rti.EndSection
Call doc.Save(True, True)
Exit Sub
