Formula help
Hi, which formula do i use to navigate from on form to another.
Subject: formula help
HI Anuj,
We are going to need a bit more information.
Are you doing it within the Lotus Notes Client or do you want to move between forms on the web?
What exactly do you mean by move from one form to another? Do you mean display one document using one form and then display another document? Or the same document with a different form?
As you can see, lots of querstions. If you can explain what you want to do with an example it will help.
Subject: RE: formula help
Hi Stephen, Actually i have 3 forms in Lotus noteswhich are interdependent.
Now what i really want is on selecting an option from a field in form1 it needs to be navigated to form 2.
Thanks for ur help in advance.
