I’m having trouble getting the conditional color change function to work while displaying my data. Instead of showing the variable value, it’s listing the RGB code in the column along with changing the color based on the value of my variable. Here’s my code:Red := 255:0:0;
DkGreen := 0:160:0;
@If(FPY > 90; DkGreen; Red)
so I get 255:0:0:0:0:0 or 0:160:0:0:0:0 in either Red or Green (depending on the value of FPY) in the column instead of the value of FPY in Red or Green.
I can sort of get it to work using:
Red := 255:0:0;
DkGreen := 0:160:0;
@Do(@If(FPY > 90; DkGreen; Red);(@ToNumber(FPY_Pass_Qty)/@ToNumber(Job_Quant)*100))
but instead of getting the value of FPY in red or green, I get either dark red or light red. Any help would be greatly appreciated! Thanks.
