I have several computers printing different font size page unexpected( the font size on these notes clients is bigger than others computers). all the documents using same form.I tried to set up “dispaly_font_adjustment = -1”, it just work on the display, the print out still not changed.
any one has good idea to explain it.
Subject: form printing problem
are you using Default Sans Serif or anyother Default type font in design? if so, these types of fonts are determined by the clients setting for this default value. Have you checked in their user preferences to see if they’ve changed the font there?
Also, I have seen some weird printing problems with Notes and PCL6 drivers. Depends if your problems is on Print only or if its screen print.
HTH
ST
Subject: RE: form printing problem
it works.
thanks stephen
