I have a form that inherits some of its fields. If I select an existing document and click create “Dup Comp” all fields that should inherit data do. If I write an outline and use a computed action of @Command([Compose];“DupServer”) then the fields do not inherit values.
This is only a problem on a Notes 8 Client !!! if the same button is used on a R5 Client it works like a champ (fields inherit their values)
Any ideas on how to fix this.
