@For and replace @ERRORS with "-" not working
Scenario:I have a key called KEY1
FIELD1 contains a list. Each element in the list is considered to be KEY1
I use @For in FIELD2 to do a lookup against that key to find me a value.
The following is happening:
FIELD1=
keyA
keyB
keyC
KeyD
The @for loop lookups using keyA and returns “A”, keyB returns “B”, keyC DOES NOT EXIST so i get an @IsError, keyD returns “D”.
FIELD2 to display the results of my @For loop displays the following: @IsError…blah blah not contained in index.
IF i write @If(@isError(lookup) ; “-” ; lookup) for the above results i get only a “-”…what I would like is my list to contain the following:
A
B
D
and NOT just a “-” or ERROR:blah, blah blah…
Is this even possible to do???
Please help with any ideas if you’re able to solve this.
ST
Subject: @For and replace @ERRORS with “-” not working
Yes – just put your @If(@IsError) stuff inside the loop to catch the error before appending it to the output value. ERROR is a flat value, and it will “eat” the array (list) you’re trying to build. Something like this:
list := “”;
@For(i:=1; i<=@Count(Field1); i:=i+1;
temp := @DbLookup(“”;“”;“view”;Field1[i];column);
@If(@IsError(temp);
temp := “-”;
list := list:temp);
@Trim(list)
Subject: RE: @For and replace @ERRORS with “-” not working
On release 6.x you can also use:
@DbLookup (“”:“NoCache” ; “” ; “view”; key ; column ; [FAILSILENT]);
the [FAILSILENT] at the end will cause the @DbLookup to return “” instead of an error.
Let’s use all those new features!
Nicolas Abesdris / PCLP
Quintessence e-solutions Inc.
Yes, let’s. Good point.
