Hello DomDevers,
I’m trying to extract data from a field that allows for multiple values and that separates the multiple values with a comma.
I need to search each character in this field until I hit a comma and then extract out the data to the left of the comma and place it in another field, do some stuff, and then continue searching the first field for more commas and data to extract until there are no more commas.
I look at Find String method but the Domino help does not give much detail about this .
Has anyone out there done this or have ideas to share?
**** Example of desired results *****
To different forms are used in this DB.
Text Field in Form 1: RequesterID = [ 1B23Y67, C876P54X, RF45567, H2J233R, ]
Search RequesterID find first comma, extract data to the left.
1B23Y67
Place in new field = [ 1B23Y67 ]
Use this as key field to find a document in Form 2 that contains this value and set a field to “Y” on Form 2.
Repeat this process until there are no more data strings to extract in the RequesterID field.
Subject: FindString method
You are working too hard at this. Just get the item and loop through the values:
dim varItem as variant
varItem=doc.FieldName
forall n in varItem
'do your thing for that n
end forall
Subject: RE: FindString method
OK sounds goodI put this bit of code in my QuerySave and I get a "member instance REQUESTRECID does not exist? I’m doing something wrong. What is it?
*** My Code ***********
Sub Querysave(Source As Notesuidocument, Continue As Variant)
Dim db As NotesDatabase
Dim view As NotesView
Dim thisView As NotesView
Dim doc As NotesDocument
Dim varItem As Variant
Set uidoc = workspace.CurrentDocument
varItem=uidoc.RequestRECID
Forall n In varItem
key = varitem
n = n + 1
Set view = db.GetView ("vwWorkupByRECID" )
Set doc = view.GetDocumentByKey (key )
doc.Quoted= "Yes"
Call doc.Save ( True, False )
Set thisView = db.GetView ("vwPWCustomer" )
Call thisView.Refresh
End Forall
Set uidoc = workspace.CurrentDocumentset doc=uidoc.document
varItem=doc.RequestRECID
can I use varItem=doc.RequestRECID if RequestRECID is a text field? I was getting a type mismatch
Post all the code please
Sorry FileSave
here it is
Set doc=uidoc.document
Forall n In varItem
key = varitem
n = n + 1
doc.Quoted= "Yes"
End Forall
Sub Postsave(Source As Notesuidocument)
Set doc=source.document
if doc.HasItem(“RequestRECID”) then
Set view = db.GetView (“vwWorkupByRECID” )
dim docLookup as NotesDocument
varItem=doc.GetItemValue(“RequestRECID”)
Forall n In varItem
Set docLookup = view.GetDocumentByKey (n)
if not (docLookup is nothing) then
docLookup.Quoted= "Yes"
Call docLookup.Save ( True, False )
else
Messagebox "Document for " & n & " not
found"
end if
End Forall
end if
