FileSave problem
I have a form with a button named “Save” by using the formula:@PostedCommand([FileSave])
I have another field to record the latest 10 Editors by using the formula:
@Left(@If(@IsDocBeingSaved; @If(Editor = “”; @Name([CN]; @UserName); @Name([CN]; @UserName) : @If(@Elements(Editor) > 9; @Subset(Editor; 9); Editor)); Editor); 25)
The problem is that if I use “Save” button to save the document, my name will not be displayed in the Editor list; If I exit the document, and choose “Yes” when system asks me “Do you want to save your change?”, then my name will be displayed as the latest Editor.
Do you know where is wrong about my code?
Thanks.
Subject: FileSave problem
perhaps your computed field needs to be refreshed, try this
@Command([FileSave]);
@PostedCommand([ViewRefreshFields])
