I’m having a lot of problems crating at fieldvalidation formula. The field is a textfield and the only allowed values should be “” ; “-” or a numeric value between 0 and 9999.
This should not be any problem, but I can’t make it work. Any ideas??
O
O
Subject: Fieldvalidation problem
create an @if using @TextToNumber( string )
something like this:
@if(
@text(field) = ""; @true;
@text(field) = "-"; @true;
@textToNumber(field) > 0 & ; @textToNumber(field) < 9999; @true;
@false
Subject: RE: Fieldvalidation problem
The following formula works just great:
@if(
@text(field) = “”; @Success;
@text(field) = “-”; @Success;
@textToNumber(field) > 0 & @textToNumber(field) < 9999; @Success;
@Failure(“Your message”)
