Field values not showing when using DECS
We have a database that is set up to use DECS to connect to an external database. Periodically, the editable field values do will not show in views. However, the computed fields do display their data. The data is there, as we can varify in the document properties, but will not display in the views. Everything seems to work fine for a few days before this problem pops up.
Any ideas on what could cause this?
Thank you.
Subject: Field values not showing when using DECS
Sounds like a problem with the IsSummary flag on the items… ?
