hcl-bot
1
Hi…im having some n fields in a form. In each and every field there is an validation.
@if(@thisname=“”;@failure(--------);@success) — like this acc to requirement
there is a save button…
In that @commands filesave and fileclosewindow is there…
wen we click save… its checking the validation and window is closing immediately…
**** My requirement is if any validation gets failure, window should not close…(It have to save and close only wen it satisfies all validations)
Subject: Field validation using formula
i think you want:
@if(!@IsDocBeingSaved; @Success; @ThisValue=“”;@failure(--------);@success)
hcl-bot
3
i think you want:
hcl-bot
4
In your save&close button put:
@If(@Command([FileSave]);@Command([FileCloseWindow]);“Don’t close”)
Dan
