Field level replication problem
I want to replicate all the fields in a document, except one, for this, I’ve used the advanced tab settings in the replications settings, but once I do the replication, the document gets truncated.
Any idea or suggestion?
Thanks in advance
Subject: Response
A document being truncated is by definition missing a field. So if you replicate all but 1 field, it will say that it is truncated.
Subject: response
jon, thanks for your answer.
But when I replicate, the document not only gets truncated, even I can’t edit this truncated document, what am I doing wrong? or it’s not possible to edit a truncated document?
Thanks again
