I have the following code behind an action button which has stopped the execution of my field level input validation. Can anyone tell me why?
add_info := @Prompt([OkCancelEdit]; “Additional Information”; “Please enter any additional information.”; " ");
SendTo := Assignees;
FIELD SaveOptions := SaveOptions;
@SetField(“Comments”; add_info);
@If(@Prompt([YesNo];“Send memo?”;“Are you ready to send this message?”);@MailSend(SendTo;DocAuthor;“”;“!!! IMPORTANT - Task Assignment.”;“”;“The attached task has been assigned to you for completion: " + @NewLine + @Name([CN];Requestor) + " is requesting the assigned task to be completed by " + @Text(reqDueDate)+”." + @NewLine + “Please click on the enclosed doclink to review the assigned task.—> “;[IncludeDoclink]);@Return(””));
Subject: Why are you using the “SaveOptions” field? You do not need it.
I would rewrite your formula as follows.
FIELD Comments := @Prompt([OkCancelEdit]; “Additional Information”; “Please enter any additional information.”; " ");
@If(@Prompt([YesNo];“Send memo?”;“Are you ready to send this message?”); “”; @Return(“”));
@If(@Command([FileSave]); “”; @Return(“”));
REM “If input validation passes…”;
@MailSend(Assignees; DocAuthor; “”; “!!! IMPORTANT - Task Assignment.”; “”; “The attached task has been assigned to you for completion: " + @NewLine + @Name([CN];Requestor) + " is requesting the assigned task to be completed by " + @Text(reqDueDate)+”." + @NewLine + "Please click on the enclosed doclink to review the assigned task.—> "; [IncludeDoclink]);
Thanks Bill,I tried your code too but it won’t validate either. I have found out that its my first @prompt which is being thrown before validation. Its not supposed to happen until after validation. Thanks in advance for any help.
Angie
(My problematic code)
I’ve changed my code to the following at your suggestion. Unfortunately its still throwing the prompt with empty fields.
Thanks,
Angie
@If(@IsValid;“”;@Return(“”));
Are you using the Input Validation objects to validate, or are you validating in the QuerySave? The QuerySave won’t fire until the [FileSave] is called.
I don’t get it, then. The @Return(“”) should stop the action before anything else is called. Could it be the case that you’re using @IsDocBeingSaved in your validation formulas? If so, there’s no way to keep anything from happening until after the save is called, and your prompts come before the [FileSave].
Stan you were right on with the @IsDocBeingSaved. I’ve made the changes and now validation works but my @mailsend isn’t.
Here’s my code now. Thanks!
Angie
