Hi everyone - I’m trying to add Help Description text to a bunch of fields in 8 but nothing is showing in the status bar. It works fine in R5 & R6 - I’m using 8.0.2 client & designer. Is there a bug or a new setting to disable it? I’ve searched but can’t find anything here or in the online support… do let me know if my search criteria was wrong!
Cheers
David
