Hi all,
i have a multivalue field which stores names of people.
i want to set these field value in other document using forall statement in lotus script.
i have using the following code…
Forall name1 In item.Values(0)
Call uidoc.FieldSetText(“Names”,name1)
End Forall
But it only attach the last name of the list, i want all
the name of the list to be set in my field…
so, please suggest me what i have to do?
Regards
Subject: Facing Problem in Forall
Read the Designer help for FieldSetText method
u will have to make a string of all the values in the List and add set the string in the UIDOC.
I suppose there is problem in your code.
instead of writting
forall name1 in item.value(0)
write
Ashish
Use FieldAppendText instead if you wish to keep appending values to the same field without over writing the existing value there (which is what you are doing currently each time through the loop).
