"External function not found" using PokeLSString alias memcpy
we’ve just made an upgrade from R5 to R8.5 and we have a problem with a scheduled agent
here’s an exemple to reproduce the error message
i tried memcpy and the new secure version memcpy_s but no way
Option Public
Option Declare
Declare Private Sub PokeLSString Lib “MSVCRT” Alias “memcpy” ( D As Long, Byval S As String, Byval C As Long)
Declare Private Sub PokeLSStringS Lib “MSVCRT” Alias “memcpy_s” ( D As Long, Byval N As Long, Byval S As String, Byval C As Long)
Sub Initialize
On Error Goto erreur
Dim Text(1023) As Long
Dim header As String
Dim size As Integer
header = "toto"
size = Len(header)
PokeLSString Text(0), header, Clng(Size)
PokeLSStringS Text(0), 1024,header, Clng(Size)
Exit Sub
erreur:
Print Error$ & " ligne " & Erl()
Resume Next
Exit Sub
any idea?
Subject: Explanation
This is not an issue w/ 8.5. Its also a problem on previous versions w/ this code. The function memcpy_s is not externalized in the version of msvcrt, so the declare statement cannot find it at runtime and throws the “External function not found” error. We would recommend that you use the WinDbg debugger’s x command to verify this, by attaching a debugger to a process (could be anything like notepad or Notes), and issuing the command:
X msvcrt!mem*
This yields the output:
77c46170 msvcrt!memccpy ()
77c461c8 msvcrt!memicmp ()
77c46e00 msvcrt!memchr ()
77c46eb0 msvcrt!memcmp ()
77c46f70 msvcrt!memcpy ()
77c472b0 msvcrt!memmove ()
77c475f0 msvcrt!memset ()
If we remove your use of the memcpy_s function the error goes away. You should determine what library this memcpy_s function is located in.
Subject: Thanks
ok, this function was used in a script for creating html emails, I’ll try another way to do it.
NotesMIMEEntity maybe?
