I’m trying to extend the LDAP Schema to include an AbbreviatedName so that I can integrate Notes IM with Sametime using LDAP.
I’ve cerated all the fields, however I may be stuck at doing the LDAP Schema.
The problem is the OID. Some documentation suggested using OID id-at-DominoAbbreviatedName, however this does not work, since the Schema.nsf does not allow me to input this.
Is it just a case of looking through the OIDs and using the next available number, or is there a methodology for when using OIDs?
Thanks in advance
