Export to MSSQL problem
I wrote a piece of agent that export data from notes document to MSSQL. I tested this agent against MS Access and it worked fine. The problem I faced using MSSQL is that only one record is created. I didn’t define Primary key in the table so I don’t think that caused the problem. Can anyone tell me if something is wrong with this code.
Sub Initialize
'LSX Declaration and setting
Dim con As New ODBCConnection
Dim qry As New ODBCQuery
Dim result As New ODBCResultSet
Set qry.Connection = con
Set result.Query = qry
Set session = New NotesSession
serverName=db.Server
Path$=fgeneratepath("")
Set dbArch = session.GetDatabase(serverName, Path$ +"ielsarchv.nsf")
'Get the view to process
Set view=dbArch.GetView("vwLookupByType")
Set docColl=view.GetalldocumentsbyKey("Team Formation")
con.ConnectTo("IELS")
'queries the table Contacts.
qry.SQL = "SELECT * FROM Team"
If docColl.Count>0 Then
	Set doc=docColl.getfirstdocument
	Do While Not (Doc Is Nothing)
		For i=0 To Ubound(doc.StudentInfoList)
			result.Execute
			result.AddRow
			Call result.SetValue("TeamID",doc.TeamID(0))
			Call result.SetValue("TeamName",doc.TeamName(0))
			Call result.SetValue("FormNo",doc.FormNo(0))
			Call result.SetValue("FormName",doc.FormName(0))
			Call result.SetValue("StudentName",fword(doc.StudentInfoList(i),"~~",2))
			Call result.SetValue("StudentID",fword(doc.StudentInfoList(i),"~~",1))
			Call result.SetValue("StudentRole",fword(doc.RoleNumber(i),"~~",1))
			Call result.SetValue("StudentPhone",fword(doc.RoleNumber(i),"~~",2))
			Call result.SetValue("DiplomaProgram",fword(doc.StudentInfoList(i),"~~",4))
			Call result.SetValue("TermNo",doc.TermNo(0))
			Call result.SetValue("TermDesc",doc.TermDesc(0))
			Call result.SetValue("AcadYear",doc.AcadYear(0))
			Call result.SetValue("CourseName",doc.CourseName(0))
			Call result.SetValue("CourseID",doc.CourseID(0))
			Call result.SetValue("CourseOffering",doc.CourseOffering(0))
			Call result.SetValue("ClassSection",doc.ClassSection(0))
			Call result.SetValue("ClassNumber",doc.ClassNumber(0))
			Call result.SetValue("Mentorname",doc.MentorName(0))
			Call result.SetValue("MentorID",doc.MentorID(0))
			result.UpdateRow
			i=i+1
		Next
		Set doc=docColl.getnextdocument(doc)
	Loop
	result.Close(DB_CLOSE)
	con.Disconnect
Subject: Export to MSSQL problem - Resolved
Thanks everyone for pointing out a few things. I realised the issue with the i loop and had that rectified. I moved the result.execute loop outside the For loop and everything work perfectly.
Regards
Place “Print result.GetExtendedErrorMessage” statement in some places in your code to find out what error you get.
Question was the one record the first or the last?
Try moving the result.execute line to before the for/next statement. I haven’t tested this, but I think you’re resetting the pointer by including it in the loop.
You could always try the insert SQL method:
INSERT [INTO] table_or_view [(column_list)] data_values
so that you collect your data values and build a new qry statement:
qry={INSERT INTO MyTable (PriKey, Description)
   VALUES (123, 'A description of part 123.')}
In addition to the other two suggestions, try moving the result.Execute outside of your For loop. You shouldn’t need to execute the query in each iteration of the addrow processing loop. I’m not sure what effect that would have on your results, if any.
And on a side note: you don’t need to increment the counter in a For loop unless you purposely want to skip entries.
hope that helps.
