Export Email - headers and body
Hello, I need to provide a button for certain people on their mail template to export the currently opened email to someplace else…
@Command([FileExport] does not export header data (from, to, subject, date, etc.).
Does anyone know the best way to handle this?
Subject: Export Email - headers and body
Thanks for all of the responses. I think the path I’m going to try to take is this:Create an Action button on the Memo form that creates a new form on the back end with all of the memo info on it, then executes an agent that exports that form information (which i haven’t implemented yet).
So far it works, except I can’t get the “From” info from the memo!!! It always appears as the same as the “SEND TO” field.
(oh… did i mention i am not very good at LS??? Just this simple code below took me a hour!!!).
Sub Click(Source As Button)
Dim Session As New NotesSession
Dim Workspace As New NotesUIWorkspace
Dim db As notesDatabase
Set UIDoc = Workspace.CurrentDocument
Set TheDocument = UIDoc.Document
Set db = New NotesDatabase("", "")
’ Open user’s mail database
db.openmail
’ Get vars from document
DisplayDate = Uidoc.FieldGetText("DisplayDate")
SendTo = Uidoc.FieldGetText("SendTo")
From2 = Uidoc.FieldGetText(“From”)
Subject =  Uidoc.FieldGetText("Subject")
Body =  Uidoc.FieldGetText("Body")
Dim MemoInfo As New NotesDocument(db)
MemoInfo.Form = "MemoInfo"
'Place string in MemoInfo fields
MemoInfo.xxFrom = Cstr(From2)
MemoInfo.xxDate = Cdat(DisplayDate)
MemoInfo.xxTo = Cstr(SendTo)
MemoInfo.xxSubject = Cstr(Subject)
MemoInfo.xxBody = Cstr(Body)
Call MemoInfo.ComputeWithForm(True,False)
Call MemoInfo.save(False, False)
Hi Diane,
Were you able to get this up running - are you able to export your mails(and attachments)??
Kjeld
Did you see this:http://www-10.lotus.com/ldd/nd6forum.nsf/55c38d716d632d9b8525689b005ba1c0/c17743e08af4c6b285256f4f00667996?OpenDocument
or any of these hits:
http://www-10.lotus.com/ldd/46dom.nsf/Search?SearchView&Query=export%20email&SearchOrder=0&Start=1&Count=100
HTH.
Gregg
I’ve never been able to figure out why that happens - I know the header is a subform but you can do one or the other (depending on focus when you hit export) but not both.
I know its a work-around - but to simplify everything I modified the Memo form in the mail file to include a couple of computed fields such as from and sentdate
I placed these below the body field (or outside the header - and then just export using the internal command.
It’s a problem if you can’t modify your template form and whenever you do a version upgrade it will overwrite the templates and you have to go back and modify again,
If a third party product is an option, our Midas Rich Text LSX will let you export to MIME, including the headers, as either a .eml file readable by Outlook or a .mht file readable by Internet Explorer (technically a Web Archive format). Otherwise, your best bet is probably using the NotesMIMEEntity class and retrieving each part.
