I need to print email to PDF for workflow process. However then I use the UIDOC.PRINT(1), the TO and CC address will be truncated if they are too long.
However, if I were to do a manual print (via File Print), I do not have this issue. Please advise how should I go about resolving this.
Subject: Expand Names Field contents when printing does not apply to UIDOC.PRINT()
i came across the same problem, somewhere i read that the environment variable EXPAND_NAMES_PRINTING=1 (or in notes.ini file) is related, but the scripts do not look at this parameter.
there may be a variable in a form that needs to be set. i’m not getting anywhere in my searches, so if anyone finds more info, please post it here.
