@Evaluate using LS
Hi
I have a problem with using evaluate in LS. The text below is in a text file(fileForSMS.txt) on my local hard drive.
I would like to extract the phone number(represented by lots of X)
Phone number: XXXXXXXXXXX Cellphone:YYYYYYYYYYYY
Adress:Blablabal
Here is the code in my agent. Somehow, the Text variable is not set by the Evaluate statement. The linein Variant is populated.
Dim filenum As Integer, filename As String, linein As String, Text As String
filename = "c:\fileForSMS.txt"
filenum% = Freefile()
Open filename For Input As filenum
Do Until Eof(filenum)
	Line Input #filenum, linein
	Dim tmpTekst As Variant
	tmpText = Evaluate({@middle(linein;"phone number: ";11)})
	Text = tmpTekst(0)
Loop
Any ideas?
Henrik
Subject: @Evaluate using LS
You can not do it on this way as “linein” is interpreted as variable inside formula context and it is always blank.Do it as :
tmpText=Left(StrRight(linein,“Phone number:”),11)
Spell “Phone number” in exact case as it appears in the file
Subject: RE: @Evaluate using LS
Works perfectly!
Thanks!
H
check the name of your variable.
it dosen’t always have the same name.
Dave
